Unlisted page
This page is unlisted. Search engines will not index it, and only users having a direct link can access it.
Version: 1.10.0
Create Docker machine on AWS EC2
Install Docker machine in AWS EC2 instance
You will need to install AWS CLI in order to do this.
$ docker-machine create --driver amazonec2 --amazonec2-access-key AKIA**** --amazonec2-secret-key **** aws
$ eval $(docker-machine env aws)
$ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
Setup VPN tunnel to the Docker machine
https://blog.ambar.cloud/tutorial-set-up-openvpn-with-docker-compose/
Create OpenVPN config dir
docker-machine ssh aws mkdir openvpn-docker
Create docker-compose.yml with the following
version: '2'
services:
openvpn:
cap_add:
- NET_ADMIN
image: kylemanna/openvpn
container_name: openvpn
ports:
- "1194:1194/udp"
restart: always
volumes:
- /home/ubuntu/openvpn-docker:/etc/openvpn
Fetch OpenVPN Docker image
docker-compose run --rm openvpn ovpn_genconfig -u udp://aws
Generate certificates
docker-compose run --rm openvpn ovpn_initpki
Start OpenVPN container
$ docker-compose up -d openvpn
$ docker ps
09934f3f52b2 kylemanna/openvpn "ovpn_run" 6 seconds ago Up 4 seconds 0.0.0.0:1194->1194/udp openvpn
Generate certificate for a client
docker-compose run --rm openvpn easyrsa build-client-full client nopass
Get config to local machine
docker-compose run --rm openvpn ovpn_getclient client > aws.ovpn
Import config to your OpenVPN client (Tunnelblick on Mac)
right click on aws.ovpn in finder and Open With -> Tunnelblick.app
Add IP address of your aws machine to /etc/hosts (might need to sudo this)
sudo sh
echo $(docker-machine ip aws-mql) aws-mql >> /etc/hosts
Before you can connect to the OpenVPN server you need to open the OpenVPN inbound port on the AWS EC2 instance
  • log into AWS console
  • go to EC2 dashboard/Security Groups/docker-machine select Inbound
  • add Custom UDP rule - protocol UDP, port 1194, source 0.0.0.0/0
  • add also HTTP (80), HTTPS (443) port for manager, 8081 (Keycloak) and 5432 PostgreSQL.
  • set in demo.yml IDENTITY_NETWORK_HOST: aws (or IP address of the AWS machine)
Now you should be able to connect Tunnelblick with the OpenVPN server, however before you do this add the default VirtualBox IP to it.
sudo vi /etc/network/interfaces
Insert the following
auto eth0:1
iface eth0:1 inet static
address 192.168.99.100
netmask 255.255.255.0
Restart networking
sudo /etc/init.d/networking restart
Now you should see the following interface on the aws instance
$ ifconfig
eth0:1 Link encap:Ethernet HWaddr 0e:9b:63:c2:cc:54
inet addr:192.168.99.100 Bcast:192.168.99.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:9001 Metric:1
It is time to open the Tunnelblick connection and you should be able to ping 192.168.99.100
$ ping 192.168.99.100
PING 192.168.99.100 (192.168.99.100): 56 data bytes
64 bytes from 192.168.99.100: icmp_seq=0 ttl=63 time=113.606 ms
Now you can use the AWS EC2 instance as a local VirtualBox Docker machine. This will save your local resources. It is compatible with current free Tier offer, so you can have it 12 months for free.
