Version: 1.13.0
Useful commands and queries
Docker
Replace <PROJECT_NAME> with value used when creating the container with docker-compose up (docker ps will show the actual names).
Restart manager Docker container
docker restart <PROJECT_NAME>_manager_1
Start interactive psql shell in postgresql container
docker exec -it <PROJECT_NAME>_postgresql_1 psql -U postgres
Insert a different manager_config.json file
docker exec <PROJECT_NAME>_manager_1 mkdir -p /deployment/manager/app
docker cp ./manager_config.json <PROJECT_NAME>_manager_1:/deployment/manager/app/manager_config.json
Insert an .mbtiles file for applying a different map
docker exec <PROJECT_NAME>_manager_1 mkdir -p /deployment/map
docker cp ./<FILE_NAME>.mbtiles <PROJECT_NAME>_manager_1:/deployment/map/mapdata.mbtiles
Copy exported data point file to local machine (exported using query below)
docker cp <PROJECT_NAME>_postgresql_1:/deployment/datapoints.csv ./
Backup/Restore OpenRemote DB
  • Optional: Exclude datapoint records from the backup using the following command: docker exec or-postgresql-1 pg_dump -Fc openremote -f /tmp/db.bak --exclude-table-data='_timescaledb_internal._hyper_*'
  • Remove the backup from within the container: docker exec or-postgresql-1 rm /tmp/db.bak
  • SCP the backup off the source server onto the destination server: e.g. scp <HOST>:~/db.bak .
Clear Syslogs older than 1 day
Restart exited containers (without using docker-compose up)
  • docker start <PROJECT_NAME>_postgresql_1
  • docker start <PROJECT_NAME>_keycloak_1
  • docker start <PROJECT_NAME>_map_1 (only if there is a map container)
  • docker start <PROJECT_NAME>_manager_1
  • docker start <PROJECT_NAME>_proxy_1
On Docker v18.02 there is a bug which means you might see the message Error response from daemon: container "<CONTAINER_ID>": already exists to resolve this simply enter the following command (you can ignore any error messages) and try starting again
docker-containerd-ctr --address /run/docker/containerd/docker-containerd.sock --namespace moby c rm $(docker ps -aq --no-trunc)
Running demo deployment
eval $(docker-machine env or-host1)
OR_ADMIN_PASSWORD=******** OR_SETUP_RUN_ON_RESTART=true OR_HOSTNAME=demo.openremote.io \
OR_EMAIL_ADMIN=support@openremote.io docker-compose -p demo up --build -d
To find out the password:
docker exec demo_manager_1 env | awk -F= '/ADMIN_PASSWORD/ {print $2}'
Enabling bash auto-completion
brew install bash-completion
fi
Cleaning up images, containers, and volumes
Working with Docker might leave exited containers and untagged images. If you build a new image with the same tag as an existing image, the old image will not be deleted but simply untagged. If you stop a container, it will not be automatically removed. The following bash function can be used to clean up untagged images and stopped containers, add it to your $HOME/.profile:
function dcleanup(){
docker rm -v $(docker ps --filter status=exited -q 2>/dev/null) 2>/dev/null
docker rmi $(docker images --filter dangling=true -q 2>/dev/null) 2>/dev/null
To remove data volumes no longer referenced by a container (deleting ALL persistent data!), use:
docker volume prune
Revert failed PostgreSQL container auto upgrade
docker exec --rm -it -v or_postgresql-data:/var/lib/postgresql/data --entrypoint=bash openremote/postgresql
mv -v data/old/* $PGDATA
rm -r data/new data/old
Bash
SSH tunnel for proxy stats
HAProxy stats web page is only accessible on localhost in our default config, this can be tunnelled to your local machine to allow access at http://localhost:8404/stats:
ssh -L 8404:localhost:8404 <HOST>
Queries
Get DB table size info
SELECT
schema_name,
relname,
pg_size_pretty(table_size) AS size,
table_size
FROM (
SELECT
pg_catalog.pg_namespace.nspname AS schema_name,
relname,
pg_relation_size(pg_catalog.pg_class.oid) AS table_size
FROM pg_catalog.pg_class
JOIN pg_catalog.pg_namespace ON relnamespace = pg_catalog.pg_namespace.oid
) t
WHERE schema_name NOT LIKE 'pg_%'
ORDER BY table_size DESC;
Data points
Export all asset data points
Export a subset of asset data points (asset and direct child assets)
Delete all asset datapoints older than N days
Importing asset data points
Drop temp table:
DROP TABLE tmp_table;
Selfsigned SSL
To add the OpenRemote selfsigned certificate to the default java keystore cacerts:
  1. Convert to p12: openssl pkcs12 -export -in proxy/selfsigned/localhost.pem -out or_selfsigned.p12 (use default password changeit
  2. Import into default java keystore: openssl pkcs12 -export -in openremote/proxy/selfsigned/localhost.pem -out or_selfsigned.p12 (Windows will need to execute this in Command Prompt with Admin permissions)
Consoles
Remove consoles that haven't registered for more than N days
DELETE FROM asset a
Notifications
Count notifications with specific title sent to consoles (Android/iOS) in past N days
SELECT count(*)
FROM notification n
Count notifications with specific title sent to consoles (Android/iOS) and acknowledged by:
Closing/Dismissing
SELECT count(*)
FROM notification n
n.acknowledgement = 'CLOSED';
Clicking the notification
SELECT count(*)
FROM notification n
n.acknowledgement IS null;
Clicking a specific action button
select count(*)
FROM notification n
