Version: 1.14.0
Working on maps
Vector maps (Mapbox GL)
The manager has built in support for Mapbox GL and can serve vector tile data. Tiles can be configured from the appearance page or through a custom deployment. Please ensure to check the following:
Uploading MBTiles
The *.mbtiles file size must be equal or less than the specified tile upload limit. The default limit is 30MB, this can be increased with OR_CUSTOM_MAP_SIZE_LIMIT. The tiles should adhere to the MBTiles specification.
OR_CUSTOM_MAP_SIZE_LIMIT: 1000000000 # 1GB
The *.mbtiles file is a SQLite database under the hood. OpenRemote validates that this contains the required metadata. In case something is missing in the metadata table (see troubleshooting).
Custom Deployment
Make sure the deployment folder contains the following files:
  • map/mapsettings.json - Contains settings related to the map tiles source data and also UI rendering settings (e.g. center point of map when first loaded)
  • map/mapdata.mbtiles - Contains the vector map data (adding it here will override the demo map for Rotterdam, located in the manager folder src/map)
If you have the map data and/or settings in a different location then please ensure that the manager environment variables are set also:
MAP_TILES_PATH=../deployment/map/mapdata.mbtiles
MAP_SETTINGS_PATH=../deployment/map/mapsettings.json
Troubleshooting
If the *.mbtiles have failed to upload, load- or display correctly please make sure to check all the required metadata fields are present.
sqlite3 -cmd "SELECT * FROM metadata;" example.mbtiles
Update or insert bounds into the metadata table.
sqlite3 -cmd "INSERT INTO metadata (name, value) VALUES ('bounds', '5.144469,51.245319,5.783558,51.647744') ON CONFLICT(name) DO UPDATE SET value = excluded.value;" example.mbtiles
See required fields
name|eindhoven # Currently ignored
attribution|<a href="https://www.maptiler.com/copyright/" target="_blank">&copy; MapTiler</a> <a href="https://www.openstreetmap.org/copyright" target="_blank">&copy; OpenStreetMap contributors</a>
bounds|5.144469,51.245319,5.783558,51.647744
center|5.464014,51.446532,7
format|pbf # Currently ignored
maxzoom|14
minzoom|0
json|{...}
Raster maps (Mapbox JS)
If you are working on raster maps (Mapbox JS) then you will need to have the map Docker container running, this container serves the raster map tiles from the vector map data.
The container can be started by using the dev-map.yml profile (see here) or you can add a map service to an existing custom project profile (copy the dev-map.yml as a template).
The manager acts as a reverse proxy for the map service and in order to configure the manager to serve raster tiles you need to set the following environment variables:
MAP_TILESERVER_HOST=localhost
MAP_TILESERVER_PORT=8082
MAP_TILESERVER_REQUEST_TIMEOUT=10000
By default MAP_TILESERVER_HOST is null which means the reverse proxy is disabled
Downloading maps and extracting smaller tilesets
We currently do not have our own pipeline for extracting/converting OSM data into vector tilesets but depend on the extracts offered on openmaptiles.org. You can download the vector mbtiles file that contains the bounding box of interest.
From that mbtiles file you can extract smaller tilesets with the following procedure:
  1. Rename the source tileset file input.mbtiles
  2. Create Docker container with node and python with dir containing input.mbtiles volume mapped: docker run -it --rm -v PATH_TO_INPUT_MBTILES_DIR:/mapdata nikolaik/python-nodejs:python3.8-nodejs12 bash
  3. Install tilelive converter: npm install -g --unsafe @mapbox/mbtiles @mapbox/tilelive
  4. Select and copy boundary box coordinates of desired region (these are the BOUNDS used in the next command; they must be in format [W,S,E,N] e.g. 4.91, 51.27, 5.84, 51.77): https://tools.geofabrik.de/calc/#tab=1 (use the coordinates in 'Simple Copy' and add the commas)
  5. Extract the desired region (adjust the zoom levels as required and optionally add --timeout=Nms if the task times out): tilelive-copy --minzoom=0 --maxzoom=14 --bounds="FILL_BOUNDS_HERE" /mapdata/input.mbtiles /mapdata/output.mbtiles
  6. Rename output.mbtiles into mapdata.mbtiles
