External Services
External services allow developers to extend the functionality of the OpenRemote platform by integrating their own applications directly into the OpenRemote Manager, giving users a seamless way to configure and manage them.
The registration process is primarily intended for services that provide a user interface. When registered, the service's web interface is embedded in the Manager Web UI using an iframe, allowing users to interact with it without leaving OpenRemote.
Services without a UI can remain fully standalone applications. They can still make use of OpenRemote's APIs but do not need to register as an external service.
Overview​
What is an External Service?​
An external service is a standalone application that communicates with OpenRemote through its APIs. When registered, it appears in the Manager Web UI with its own embedded web interface, enabling direct interaction from within OpenRemote.
External services can be built using any programming language or framework. They should be viewed as independent applications that extend the platform's capabilities while leveraging OpenRemote for integration and management.
Types of External Services​
There are two types of external services in OpenRemote:
Global Services
  • Registered using the /service/global endpoint
  • Must be registered via the master realm
  • Require a Service User with Super User privileges for registration
  • Once registered, they are available and listed on all realms
  • Typically designed with multi-tenancy in mind, but this is not strictly required
Regular Services
  • Registered using the /service endpoint
  • Bound to a specific realm and only available within that realm (single-tenant)
  • Simpler to implement when multi-tenancy is not required
Both global and regular services must be registered by Service Users. Global services specifically require a Super User account in the master realm, while regular services can be registered with a realm-specific Service User. For more information on Service Users, see Realm Users and Roles and Security.
Development​
Creating an external service involves building a standalone application that integrates with OpenRemote. Below is a step-by-step guide to developing your own service.
Step 1: Build Your Application​
External services can be built using any programming language or framework (Python, Node.js, Java, Go, etc.). Your application should:
  • Provide the core functionality you want to extend OpenRemote with (e.g., ML forecasting, data analysis, device management)
  • Expose a web server with both:
    • A web interface (HTML/CSS/JavaScript) that users will interact with
    • API endpoints for communication with OpenRemote
  • Be packaged as a Docker container for easy deployment
Technology choices:
  • Backend: Use any language/framework (FastAPI, Express, Spring Boot, etc.)
  • Frontend: Use any web framework (React, Vue, Svelte, vanilla JavaScript, etc.)
  • Optional: Use OpenRemote's web components (buttons, panels, forms, tables) for a consistent UI that matches the Manager
Step 2: Make Your Web Interface Iframe-Compatible​
Since your service's web interface will be embedded in the OpenRemote Manager using an iframe, ensure it meets these requirements:
Technical Requirements:
  • Same origin and protocol: Use the same domain and protocol (HTTP/HTTPS) as the OpenRemote Manager (no mixed content)
  • Headers: Configure your web server to allow iframe embedding:
    • Avoid X-Frame-Options: DENY or overly restrictive Content-Security-Policy
    • Recommended: Content-Security-Policy: frame-ancestors 'self' https://<manager-domain>
  • Responsive design: The iframe may resize; ensure your UI adapts dynamically
  • Navigation: Avoid pop-ups or full-page redirects; keep all interactions within the iframe
Step 3: Implement Registration Logic​
Your service must register itself with OpenRemote on startup. This involves:
  1. On application startup, send a POST request to /service (realm-specific) or /service/global (global)
  2. Include service details in the request body (see Registration section below for format)
  3. Store the instanceId returned in the response—you'll need it for heartbeats
  4. Use your Service User credentials for authentication
This logic should run during your application's initialization phase, typically in your main startup code or initialization function.
Step 4: Implement Heartbeat Mechanism​
Your service must continuously signal that it's alive and operational:
  1. Implement a background task (scheduled job, async loop, cron job, etc.) that runs periodically
  2. Send PUT /service/{serviceId}/{instanceId} with your serviceId and instanceId as path parameters
  3. Send heartbeats every 30-50 seconds (must be less than 60 seconds to avoid being marked unavailable)
  4. Handle failures gracefully—if a heartbeat fails, retry or re-register if needed
Example pseudo-code structure:
# On startup
instance_id = register_service()
# Background task
while True:
send_heartbeat(instance_id)
sleep(30) # seconds
Step 5: Integrate with OpenRemote APIs​
Your service can interact with OpenRemote's APIs to read and write data:
  • Authentication: Use OAuth2 with your Service User credentials
  • Read data: Query assets, attributes, historical data
  • Write data: Update attribute values, create assets
  • Listen for events: Subscribe to asset/attribute changes via WebSocket or MQTT
Refer to the OpenRemote API documentation for available endpoints.
Security Considerations​
When developing your external service, follow these security best practices:
  • Authentication: Integrate with Keycloak (OpenRemote's identity provider) to ensure only authorized users can access your service UI
  • Authorization: Validate that users have appropriate permissions before exposing sensitive functionality
  • Protocol: Always use HTTPS in production to protect data integrity and confidentiality
  • Secrets management: Store Service User credentials and API keys securely using environment variables or secret management tools
  • CORS: If hosting on a different domain, configure Cross-Origin Resource Sharing (CORS) appropriately. Note that using a different domain may complicate Keycloak integration
Registration​
Request Format​
As described in Step 3 of the Development section, your service must send a registration request on startup. Below are the details of the API format.
Example registration request body:
"serviceId": "my-service",
"label": "My External Service",
"icon": "mdi-cloud",
"homepageUrl": "https://my-external-service.com/interface",
"status": "AVAILABLE"
OpenRemote responds with the same ExternalService object, but with an additional field, instanceId, which uniquely identifies the service and must be included in subsequent heartbeat requests.
API Endpoints​
EndpointMethodScopePurpose
/servicePOSTRealmRegister a realm-specific external service
/service/globalPOSTGlobalRegister a global external service (master realm only)
/service/{serviceId}/{instanceId}PUTBothSend periodic heartbeat
The exact API endpoint and request format can be found in the OpenRemote API documentation.
Heartbeat Format​
As described in Step 4 of the Development section, your service must send periodic heartbeat requests. Below are the technical details.
Request details:
  • Endpoint: PUT /service/{serviceId}/{instanceId}
  • Path parameters: serviceId and instanceId (received during registration)
  • Frequency: Every 30-50 seconds (TTL is 60 seconds)
  • Response: 204 No Content on success
If OpenRemote does not receive a heartbeat within the 60-second TTL, the service is marked as unavailable in the Manager UI.
Registration and Heartbeat Flow:
The diagram below illustrates the complete registration and heartbeat process:
Deployment​
Docker Compose Setup​
External services can be deployed alongside the OpenRemote stack using Docker Compose. The easiest approach is to add your service to an existing Docker Compose profile or create a custom one. For the instructions below, we will use the ML Forecast Service as an example.
Example service (service-ml-forecast) configuration:
volumes:
service-ml-forecast-data:
services:
ml-forecast:
image: openremote/service-ml-forecast:latest
restart: always
environment:
ML_LOG_LEVEL: INFO
ML_ENVIRONMENT: production
ML_WEBSERVER_ORIGINS: '["https://${OR_HOSTNAME:-localhost}"]'
ML_OR_URL: https://${OR_HOSTNAME:-localhost} # OpenRemote Manager URL
ML_OR_KEYCLOAK_URL: https://${OR_HOSTNAME:-localhost}/auth # Keycloak Auth URL
ML_OR_SERVICE_USER: ${ML_OR_SERVICE_USER:-serviceuser} # Service User
ML_OR_SERVICE_USER_SECRET: ${ML_OR_SERVICE_USER_SECRET:-secret} # Service User Secret
ML_OR_SERVICE_URL: https://${OR_HOSTNAME:-localhost} # The homepageUrl of the service
volumes:
- service-ml-forecast-data:/app/deployment/data
For more information on the service configuration, refer to the ML Forecast Service repository.
Service User Configuration​
Your external service will need a service user account in OpenRemote for API authentication. You can create the Service User via the OpenRemote Manager UI. The service user credentials should be provided via environment variables and kept secure. For the service being able to register to OpenRemote, the role write:services is required.
Reverse Proxy Configuration​
If you want to use OpenRemote's reverse proxy (HAProxy) to route traffic to your external service:
1. Enable Custom HAProxy Configuration
proxy:
environment:
HAPROXY_CONFIG: '/data/proxy/haproxy.cfg'
volumes:
- proxy-data:/deployment
- deployment-data:/data
2. Create Custom HAProxy Configuration
Create a custom haproxy.cfg file based on the base configuration and place it at deployment/proxy/haproxy.cfg.
Add frontend routing:
acl ml-forecast path_beg /services/ml-forecast
use_backend ml-forecast if ml-forecast
Add backend configuration:
backend ml-forecast
server ml-forecast ml-forecast:8000 resolvers docker_resolver
Examples​
Use Cases​
External services can be used to extend OpenRemote in many ways:
  • AI/LLM Integration: Connect AI services (e.g., ChatGPT, Claude) to provide contextual querying of devices, assets, and data
  • Machine Learning: Implement predictive maintenance, energy optimization, or anomaly detection
  • Firmware Management: Manage and deploy firmware updates to connected devices
Reference Implementation​
We provide the ML Forecast Service which can serve as a reference implementation. This service connects to OpenRemote, retrieves historical data, and provides forecasting capabilities using machine learning/statistical models.
It demonstrates how to implement:
  • Registration logic at service startup
  • Heartbeat mechanism as a background task
  • OAuth2 authentication with OpenRemote's APIs for data retrieval and writing
  • Keycloak integration for user authentication
  • Web interface using OpenRemote's web components for a consistent UI
Reviewing this implementation will give you a clear example of how to structure your own external service, including the complete registration and heartbeat implementation code.
Summary​
By leveraging external services, developers can extend and enhance the OpenRemote platform in a flexible manner:
  • Registration connects services with a UI to the Manager, embedding their interface directly
  • Global vs regular services allow flexibility between multi-tenant and realm-specific use cases
  • Heartbeats ensure service availability is tracked in real time
  • Security best practices help ensure safe and reliable integrations
Together, these mechanisms provide a way to extend OpenRemote while maintaining a unified and secure user experience.
