Maintaining an installation
Monitoring​
Tail log output of all containers with docker-compose -p openremote -f profile/demo.yml logs -f.
Use docker stats to show CPU, memory, network read/writes, and total disk read/writes for running containers.
Diagnosing database problems​
Access the database:
docker exec -it openremote_postgresql_1 psql -U postgres
Get statistics for all tables and indices (note that these are collected statistics, not live data):
SELECT
t.tablename,
indexname,
c.reltuples AS approximate_row_count,
pg_size_pretty(pg_relation_size(quote_ident(t.tablename)::text)) AS table_size,
pg_size_pretty(pg_relation_size(quote_ident(indexrelname)::text)) AS index_size,
CASE WHEN indisunique THEN 'Y'
ELSE 'N'
END AS UNIQUE,
idx_scan AS number_of_scans,
idx_tup_read AS tuples_read,
idx_tup_fetch AS tuples_fetched
FROM pg_tables t
LEFT OUTER JOIN pg_class c ON t.tablename=c.relname
LEFT OUTER JOIN
( SELECT c.relname AS ctablename, ipg.relname AS indexname, x.indnatts AS number_of_columns, idx_scan, idx_tup_read, idx_tup_fetch, indexrelname, indisunique FROM pg_index x
JOIN pg_class c ON c.oid = x.indrelid
JOIN pg_class ipg ON ipg.oid = x.indexrelid
JOIN pg_stat_all_indexes psai ON x.indexrelid = psai.indexrelid )
AS foo
ON t.tablename = foo.ctablename
WHERE t.schemaname='openremote'
ORDER BY 1,2;
Find transactions/queries waiting for more than 30 seconds:
SELECT pid, client_addr, now() - query_start AS duration, query, state
FROM pg_stat_activity
WHERE now() - query_start > interval '30 seconds';
Kill them with:
select pg_cancel_backend(pid);
Pay attention to shared memory setting of postgres container; Docker sets this very low by default and this will cause problems for any reasonable size DB, see here for info:
More useful queries and maintenance operations can be found here:
You can log all queries taking longer than 2 seconds:
alter system set log_min_duration_statement=2000;
select pg_reload_conf();
show log_min_duration_statement;
To disable, set the duration to -1.
Use explain analyze <SQL query> to obtain the query plan and display it in https://explain.depesz.com/.
Diagnosing JVM memory problems​
Output contains:
MC: Metaspace capacity (kB).
The output contains:
docker exec -it openremote_manager_1 /usr/bin/jcmd 1 GC.run
Install the JDK​
Performing a heap dump (jmap)​
Create heap dump​
Copy to Docker host​
Use scp to copy from Docker host to local machine​
scp {HOST}:~/dump.hprof ~
Performing a thread dump (jstack)​
Create thread dump​
scp {HOST}:~/threads.txt ~
