Preparing the environment
To build OpenRemote projects, you have to first prepare the environment on your developer workstation or build machine. Alternatively you can use a Docker image with tooling.
Ensure you have installed and configured the following tools:
Runtime tooling​
To run docker images from Docker Hub you need to install the following tooling:
If you want to manage remote Docker engines then you will also need to install docker-machine separately (since docker 2.2.x):
Ensure the following commands execute successfully:
docker ps
docker-compose version
If you installed Docker machine then make sure the following command executes successfully:
docker-machine version
Development tooling​
For development you need the following in addition to the runtime tooling:
java -version
git --version
node -v
yarn -v
Ensure that you have the JAVA_HOME environment variable set to the path of JDK.
See also​
