Working on maps
MapLibre GL​
The manager has built in support for MapLibre GL and can serve vector tile data. Tiles can be configured from the appearance page or through a custom deployment. Please ensure to check the following:
Uploading MBTiles​
The *.mbtiles file size must be equal or less than the specified tile upload limit. The default limit is 30MB, this can be increased with OR_CUSTOM_MAP_SIZE_LIMIT. The tiles should adhere to the MBTiles specification.
OR_CUSTOM_MAP_SIZE_LIMIT: 1000000000 # 1GB
The *.mbtiles file is a SQLite database under the hood. OpenRemote validates that this contains the required metadata. In case something is missing in the metadata table (see troubleshooting).
Custom Deployment​
Make sure the deployment folder contains the following files:
  • map/mapsettings.json - Contains settings related to the map tiles source data and also UI rendering settings (e.g. center point of map when first loaded)
  • map/mapdata.mbtiles - Contains the vector map data (adding it here will override the demo map for Rotterdam, located in the manager folder src/map)
If you have the map data and/or settings in a different location then please ensure that the manager environment variables are set also:
MAP_TILES_PATH=../deployment/map/mapdata.mbtiles
MAP_SETTINGS_PATH=../deployment/map/mapsettings.json
Troubleshooting​
If the *.mbtiles have failed to upload, load- or display correctly please make sure to check all the required metadata fields are present.
sqlite3 -cmd "SELECT * FROM metadata;" example.mbtiles
Update or insert bounds into the metadata table.
sqlite3 -cmd "INSERT INTO metadata (name, value) VALUES ('bounds', '5.144469,51.245319,5.783558,51.647744') ON CONFLICT(name) DO UPDATE SET value = excluded.value;" example.mbtiles
See required fields
name|eindhoven # Currently ignored
attribution|<a href="https://www.maptiler.com/copyright/" target="_blank">&copy; MapTiler</a> <a href="https://www.openstreetmap.org/copyright" target="_blank">&copy; OpenStreetMap contributors</a>
bounds|5.144469,51.245319,5.783558,51.647744
center|5.464014,51.446532,7
format|pbf # Currently ignored
maxzoom|14
minzoom|0
json|{...}
Geocoding​
The map component includes built-in geocoding support using Nominatim (OpenStreetMap's geocoding service) via the @maplibre/maplibre-gl-geocoder library. When enabled, a search box is shown on the map that supports both forward geocoding (address to coordinates) and reverse geocoding (coordinates to address).
For configuring the geocode URL and setting up a self-hosted Nominatim instance, see the user guide: Geocoding.
Enabling geocoding in or-map​
The <or-map> web component has a showGeoCodingControl boolean property (default: false) that controls whether the geocoding search box is rendered. In the Manager app (ui/app/manager/src/pages/page-map.ts), geocoding is enabled by default:
<or-map id="map" class="or-map"
@or-map-geocoder-change="${(ev: OrMapGeocoderChangeEvent) => {
this._setCenter(ev.detail.geocode);
</or-map>
To enable geocoding in your own component:
<or-map
.showGeoCodingControl="${true}"
@or-map-geocoder-change="${(ev) => {
// ev.detail.geocode contains the selected result
// ev.detail.geocode.geometry.coordinates = [lng, lat]
// ev.detail.geocode.place_name = display name
console.log('Selected:', ev.detail.geocode.place_name);
</or-map>
The geocoding control only initializes when both showGeoCodingControl is true and a valid geocodeUrl is present in the realm's map settings (mapsettings.json). If no geocodeUrl is configured, the search box will not appear even if showGeoCodingControl is set.
How it works​
The MapWidget class (ui/component/or-map/src/mapwidget.ts) handles the geocoding logic. It registers a MaplibreGeocoder control that sends requests to the Nominatim API:
  • Forward: {geocodeUrl}/search?q={query}&format=geojson&polygon_geojson=1&addressdetails=1
  • Reverse: {geocodeUrl}/reverse?lat={lat}&lon={lon}&format=geojson&polygon_geojson=1&addressdetails=1
The geocodeUrl is read from the realm's ViewSettings, which are loaded from mapsettings.json via MapService.
or-map-geocoder-change event​
When the user selects a geocoding result, the or-map-geocoder-change event is fired. The event detail contains:
geocode: {
geometry: {
coordinates: [lng, lat] // longitude, latitude
place_name: string, // display name of the result
properties: object // additional address details from Nominatim
Downloading maps and extracting smaller tilesets​
We currently do not have our own pipeline for extracting/converting OSM data into vector tilesets but depend on the extracts offered on openmaptiles.org. You can download the vector mbtiles file that contains the bounding box of interest.
From that mbtiles file you can extract smaller tilesets with the following procedure:
  1. Rename the source tileset file input.mbtiles
  2. Create Docker container with node and python with dir containing input.mbtiles volume mapped: docker run -it --rm -v PATH_TO_INPUT_MBTILES_DIR:/mapdata nikolaik/python-nodejs:python3.8-nodejs12 bash
  3. Install tilelive converter: npm install -g --unsafe @mapbox/mbtiles @mapbox/tilelive
  4. Select and copy boundary box coordinates of desired region (these are the BOUNDS used in the next command; they must be in format [W,S,E,N] e.g. 4.91, 51.27, 5.84, 51.77): https://tools.geofabrik.de/calc/#tab=1 (use the coordinates in 'Simple Copy' and add the commas)
  5. Extract the desired region (adjust the zoom levels as required and optionally add --timeout=Nms if the task times out): tilelive-copy --minzoom=0 --maxzoom=14 --bounds="FILL_BOUNDS_HERE" /mapdata/input.mbtiles /mapdata/output.mbtiles
  6. Rename output.mbtiles into mapdata.mbtiles
