Working on UI and apps
Overview​
Working on an app (e.g. Manager UI)​
  • From the main directory, start the required containers, use dev-ui.yml for example:
    docker-compose -f profile/dev-ui.yml up -d
    By default, this makes the manager container serve the apps present in the latest docker image on port 8080 e.g. http://localhost:8080/manager/ . While these apps are not necessary for this case, the included manager container webservice is.
  • cd into the app directory e.g. ui/app/manager and run the following npm script:
    npm run serve
Webpack dev server environment variables​
The following environment variables can be set when running npm run serve using the syntax npm run serve "--" --env ENV_NAME=ENV_VALUE:
  • managerUrl - By default webpack dev server expects the manager to be available at http://localhost:8080 but this can be configured for example when running the manager Docker image (e.g. npm run serve "--" --env managerUrl=https://localhost)
  • keycloakUrl - By default Keycloak expects to be available at managerUrl/auth but this can be configured for example when running the manager Docker image (e.g. npm run serve "--" --env keycloakUrl=https://keycloak/auth)
Consuming UI components​
UI development​
  • Front end applications
  • Front end components and their demos, shared between applications
  • Keycloak theme(s) used in authentication screens
UI Components & Apps (/ui)​
  • component - Base OpenRemote JS modules and web components (built using Polymer) these are written as ES6 modules
  • app - Built-in OpenRemote web applications (applications can be built with whatever frameworks/libraries are desired)
  • demo - Demos of each web component (provides a development harness for developers working on the components)
  • clean - Cleans up any build artefacts (typically uses the shx package)
  • build - Build the component/app ready for publishing/deployment
  • test - Run any automated tests
  • modelWatch - Starts a gradle task to watch the java model code and to run the typescript generator when changes are detected, the generated model and restclient typescript code is then transpiled to javascript
  • modelBuild - Similar to modelWatch but just does a onetime build rather than watching for changes
  • serve - Starts webpack dev server typically on http://localhost:9000/[app|demo]/
Running Manager UI against remote instance​
  • Add https://localhost/* to Valid redirect URIs of openremote client in master realm of remote instance keycloak
  • Ensure remote instance manager container has localhost listed in OR_ADDITIONAL_HOSTNAMES (note this variable is comma separated list of hostnames)
  • Run the dev-proxy.yml compose profile locally
  • Access shell in proxy container: docker exec -it <PROXY_CONTAINER_NAME> ash
  • Add the following snippets to the proxy config (Press i for insert mode, when finished press Esc then : then wq): vi /etc/haproxy/haproxy.cfg
    • Above the use_backend manager_backend line
acl webpack path_beg /manager
  • Above the backend manager_backend line:
  • Ctrl/Cmd-D to exit the proxy container shell
  • Start the webpack dev server in the ui/app/manager: npm run serve "--" --env managerUrl=https://demo.openremote.app
Components​
Maps​
Apps​
Demos​
