WebSocket
Connect to a WebSocket (ws/wss) Server.
Agent configuration​
AttributeDescriptionValue typeRequired
connectURLWebSocket connection URL (ws/wss); this is used as the base URL for all requests that go through this agentHTTP URLY
connectHeadersHeaders to be added to the initial connection requestMultivalued Text MapN
connectSubscriptionsList of subscriptions that should be made when the protocol connects to the WebSocket serverWebSocket Subscription[]N
WebSocket Subscriptions​
The subscription attribute allows a set of subscriptions to be made when the connection is first established, these subscriptions are executed in the order they appear in the list/array. A subscription can be a WebSocket subscription or a HTTP subscription (a simple HTTP request), this covers most real world WebSocket server use cases, as this is a publish-subscribe protocol you quite often need to specify what you want to subscribe to when you connect.
typeAgent typeText (Must be WebsocketAgentLink)Y
websocketSubscriptionsList of subscriptions that should be made when this attribute is linked to the agentWebSocket Subscription[]N
