Version: 1.19.0
Data migration
DB Functions​
https://github.com/openremote/core/blob/main/manager/src/main/resources/org/openremote/manager/setup/database
Examples​
Add/Update meta items to specific attribute of asset(s)​
FROM asset a WHERE...;
Remove meta items from specific attribute of asset(s)​
Remove attributes from specific asset(s)​
Add attribute to specific asset(s) (with meta items)​
Add attribute to specific asset(s) (without meta items)​
