Version: 1.25.0
Preparing the environment
To build OpenRemote projects, you have to first prepare the environment on your developer workstation or build machine. Alternatively you can use a Docker image with tooling.
Ensure you have installed and configured the following tools:
Runtime tooling​
OpenRemote is primarily packaged as Docker images and deployed using docker compose, you will need a docker compatible runtime:
Ensure the following commands execute successfully:
docker -v
docker-compose -v
Development tooling​
For development you need the following in addition to the runtime tooling:
java -version
git --version
node -v
yarn -v
Ensure that you have the JAVA_HOME environment variable set to the path of JDK.
See also​
