Disconnect a user session using a session ID
GEThttps://demo.openremote.io/api/master/user/:realm/disconnect/:sessionID
sessionID stringrequired
any
curl -L 'https://demo.openremote.io/api/master/user/:realm/disconnect/:sessionID' \
