Retrieve the gateway tunnel information of tunnel for a gateway in a realm
GET/gateway/tunnel/:realm/:id/:target/:targetPort
id stringrequired
target stringrequired
targetPort int32required
gatewayIdstring
targetPortint32
targetstring
assignedPortint32
hostnamestring
typestring
Possible values: [HTTPS, HTTP, TCP]
autoCloseTimedate-time
  "gatewayId": "string",
  "targetPort": 0,
  "target": "string",
  "assignedPort": 0,
  "hostname": "string",
  "type": "HTTPS",
  "autoCloseTime": "2024-07-29T15:51:28.071Z",
  "id": "string"
