Retrieve the syslog configuration
GET/syslog/config
storedLevelstringrequired
Possible values: [INFO, WARN, ERROR]
storedCategoriesstring[]required
Possible values: [ASSET, AGENT, NOTIFICATION, ALARM, RULES, PROTOCOL, GATEWAY, MODEL_AND_VALUES, API, DATA]
storedMaxAgeMinutesint32required
