Retrieve a dashboard
GET/dashboard/:realm/:dashboardId
dashboardId stringrequired
realmstringrequired
ownerIdstring
viewAccessstring
editAccessstring
displayNamestringrequired
template
required
columnsint32
Possible values: >= 1
maxScreenWidthint32
refreshIntervalstring
screenPresets
required
breakpointint32
scalingPresetstringrequired
redirectDashboardIdstring
widgets
gridItem
required
xint32
yint32
wint32
hint32
minHint32
minWint32
minPixelHint32
minPixelWint32
noResizeboolean
noMoveboolean
lockedboolean
widgetTypeIdstringrequired
widgetConfigobject
