Retrieve the active gateway tunnel information of gateway in a realm
GET/gateway/tunnel/:realm/:id
id stringrequired
gatewayIdstring
targetPortint32
targetstring
assignedPortint32
hostnamestring
typestring
Possible values: [HTTPS, HTTP, TCP]
autoCloseTimedate-time
