Retrieve a global ruleset
GET/rules/:id
id int64required
idint64
lastModifieddate-time
namestringrequired
rulesstring
langstringrequired
errorstring
"id": 0,
"enabled": true,
"rules": "string",
"lang": "JAVASCRIPT",
"meta": {},
"status": "READY",
"error": "string"
