Retrieve roles for a realm
GET/user/:realm/roles
descriptionstring
compositeboolean
assignedboolean
compositeRoleIdsstring[]
    "description": "string",
    "composite": true,
    "assigned": true,
    "compositeRoleIds": [
      "string"
