Retrieve dashboards using a query
POST/dashboard/query
select
conditions
dashboard
asset
Possible values: [RESTRICTED, LINKED, REALM]
Possible values: [AT_LEAST_ONE, ALL, NONE]
parents
names
realm
template
required
Possible values: >= 1
screenPresets
required
widgets
gridItem
required
