Update attribute values with timestamps
PUT/asset/attributes/timestamp
Bodyarray
array
attributeState
ref
The asset identifier
7Bt8M3cXEP6BHPh8r47DYfThe attribute name
locationref
locationtype
ref
locationPossible values: [ASSET_NOT_FOUND, ATTRIBUTE_NOT_FOUND, INSUFFICIENT_ACCESS, INVALID_VALUE, INTERCEPTOR_FAILURE, STATE_STORAGE_FAILED, CANNOT_PROCESS, QUEUE_FULL, UNKNOWN, ASSET_ID_MISSING, ATTRIBUTE_NAME_MISSING]
