Write to a single attribute
PUT/asset/:assetId/attribute/:attributeName
assetId stringrequired
attributeName stringrequired
The result of the write operation
ref
The asset identifier
Example:
7Bt8M3cXEP6BHPh8r47DYfnamestringrequired
The attribute name
Example:
locationfailurestring
Possible values: [ASSET_NOT_FOUND, ATTRIBUTE_NOT_FOUND, INSUFFICIENT_ACCESS, INVALID_VALUE, INTERCEPTOR_FAILURE, STATE_STORAGE_FAILED, CANNOT_PROCESS, QUEUE_FULL, UNKNOWN, ASSET_ID_MISSING, ATTRIBUTE_NAME_MISSING]
