WebSocket
Connect to a WebSocket (ws/wss) Server.
Agent configuration
| Attribute | Description | Value type | Required |
connectURL | WebSocket connection URL (ws/wss); this is used as the base URL for all requests that go through this agent | HTTP URL | Y |
connectHeaders | Headers to be added to the initial connection request | Multivalued Text Map | N |
connectSubscriptions | List of subscriptions that should be made when the protocol connects to the WebSocket server | WebSocket Subscription[] | N |
WebSocket Subscriptions
The subscription attribute allows a set of subscriptions to be made when the connection is first established, these subscriptions are executed in the order they appear in the list/array. A subscription can be a WebSocket subscription or a HTTP subscription (a simple HTTP request), this covers most real world WebSocket server use cases, as this is a publish-subscribe protocol you quite often need to specify what you want to subscribe to when you connect.
Agent link
type | Agent type | Text (Must be WebsocketAgentLink) | Y |
websocketSubscriptions | List of subscriptions that should be made when this attribute is linked to the agent | WebSocket Subscription[] | N |
