Version: 1.4.0
Data migration
DB Functions
https://github.com/openremote/openremote/blob/master/manager/src/main/resources/org/openremote/manager/setup/database
Examples
Add/Update meta items to specific attribute of asset(s)
FROM asset a WHERE...;
Remove meta items from specific attribute of asset(s)
Remove attributes from specific asset(s)
Add attribute to specific asset(s) (with meta items)
Add attribute to specific asset(s) (without meta items)
