Version: 1.4.0
Useful commands and queries
Docker
Replace <PROJECT_NAME> with value used when creating the container with docker-compose up (docker ps will show the actual names).
Restart manager Docker container
docker restart <PROJECT_NAME>_manager_1
Start interactive psql shell in postgresql container
docker exec -it <PROJECT_NAME>_postgresql_1 psql -U postgres
Insert a different manager_config.json file
docker exec <PROJECT_NAME>_manager_1 mkdir -p /deployment/manager/app
docker cp ./manager_config.json <PROJECT_NAME>_manager_1:/deployment/manager/app/manager_config.json
Insert an .mbtiles file for applying a different map
docker exec <PROJECT_NAME>_manager_1 mkdir -p /deployment/map
docker cp ./<FILE_NAME>.mbtiles <PROJECT_NAME>_manager_1:/deployment/map/mapdata.mbtiles
Copy exported data point file to local machine (exported using query below)
docker cp <PROJECT_NAME>_postgresql_1:/deployment/datapoints.csv ./
Backup/Restore OpenRemote DB
  • SCP the backup off the source server onto the destination server
Clear Syslogs older than 1 day
Restart exited containers (without using docker-compose up)
  • docker start <PROJECT_NAME>_postgresql_1
  • docker start <PROJECT_NAME>_keycloak_1
  • docker start <PROJECT_NAME>_map_1 (only if there is a map container)
  • docker start <PROJECT_NAME>_manager_1
  • docker start <PROJECT_NAME>_proxy_1
On Docker v18.02 there is a bug which means you might see the message Error response from daemon: container "<CONTAINER_ID>": already exists to resolve this simply enter the following command (you can ignore any error messages) and try starting again
docker-containerd-ctr --address /run/docker/containerd/docker-containerd.sock --namespace moby c rm $(docker ps -aq --no-trunc)
Running demo deployment
eval $(docker-machine env or-host1)
OR_ADMIN_PASSWORD=******** OR_SETUP_RUN_ON_RESTART=true OR_HOSTNAME=demo.openremote.io \
OR_EMAIL_ADMIN=support@openremote.io docker-compose -p demo up --build -d
To find out the password:
docker exec demo_manager_1 env | awk -F= '/ADMIN_PASSWORD/ {print $2}'
Enabling bash auto-completion
brew install bash-completion
fi
Cleaning up images, containers, and volumes
Working with Docker might leave exited containers and untagged images. If you build a new image with the same tag as an existing image, the old image will not be deleted but simply untagged. If you stop a container, it will not be automatically removed. The following bash function can be used to clean up untagged images and stopped containers, add it to your $HOME/.profile:
function dcleanup(){
docker rm -v $(docker ps --filter status=exited -q 2>/dev/null) 2>/dev/null
docker rmi $(docker images --filter dangling=true -q 2>/dev/null) 2>/dev/null
To remove data volumes no longer referenced by a container (deleting ALL persistent data!), use:
docker volume prune
Revert failed PostgreSQL container auto upgrade
docker exec --rm -it -v or_postgresql-data:/var/lib/postgresql/data --entrypoint=bash openremote/postgresql
mv -v data/old/* $PGDATA
rm -r data/new data/old
Queries
Get DB table size info
SELECT
schema_name,
relname,
pg_size_pretty(table_size) AS size,
table_size
FROM (
SELECT
pg_catalog.pg_namespace.nspname AS schema_name,
relname,
pg_relation_size(pg_catalog.pg_class.oid) AS table_size
FROM pg_catalog.pg_class
JOIN pg_catalog.pg_namespace ON relnamespace = pg_catalog.pg_namespace.oid
) t
WHERE schema_name NOT LIKE 'pg_%'
ORDER BY table_size DESC;
Data points
Export all asset data points
Export a subset of asset data points (asset and direct child assets)
Delete all asset datapoints older than N days
Importing asset data points
Drop temp table:
DROP TABLE tmp_table;
Selfsigned SSL
To add the OpenRemote selfsigned certificate to the default java keystore cacerts:
  1. Convert to p12: openssl pkcs12 -export -in proxy/selfsigned/localhost.pem -out or_selfsigned.p12 (use default password changeit
  2. Import into default java keystore: openssl pkcs12 -export -in openremote/proxy/selfsigned/localhost.pem -out or_selfsigned.p12 (Windows will need to execute this in Command Prompt with Admin permissions)
Consoles
Remove consoles that haven't registered for more than N days
DELETE FROM asset a
Notifications
Count notifications with specific title sent to consoles (Android/iOS) in past N days
SELECT count(*)
FROM notification n
Count notifications with specific title sent to consoles (Android/iOS) and acknowledged by:
Closing/Dismissing
SELECT count(*)
FROM notification n
n.acknowledgement = 'CLOSED';
Clicking the notification
SELECT count(*)
FROM notification n
n.acknowledgement IS null;
Clicking a specific action button
select count(*)
FROM notification n
