Version: 1.4.0
Create a global ruleset
POST
https://demo.openremote.io/api/master/rules
    idint64
    lastModifieddate-time
    namestringrequired
    rulesstring
    langstringrequired
    meta object
    property name*object
    errorstring
    integerint64
curl -L 'https://demo.openremote.io/api/master/rules' \
-d '{
"id": 0,
"enabled": true,
"rules": "string",
"lang": "JAVASCRIPT",
"meta": {},
"status": "READY",
"error": "string"
Request Collapse all
Base URL
Auth
Parameters
— header
— header
— header
  "id": 0,
  "enabled": true,
  "rules": "string",
  "meta": {},
  "status": "READY",
  "error": "string"
