Version: 1.4.0
Create a new user in a realm
POST
https://demo.openremote.io/api/master/user/:realm/users
    realmIdstring
    firstNamestring
    lastNamestring
    emailstring
    secretstring
    attributes object
    property name* string[]
  • Array [
  • string
  • serviceAccountboolean
    usernamestring
    Possible values: >= 3 characters and <= 255 characters, Value must match regular expression ^(?=[\p{IsLatin}|\p{IsCommon}]+$)(?=[^<>&"'\s\v\h$%!#?§,;:*~/\\|^=\[\]{}()\p{Cntrl}]+$).*$`
    realmIdstring
    firstNamestring
    lastNamestring
    emailstring
    secretstring
    attributes object
  • Array [
  • string
    usernamestring
curl -L 'https://demo.openremote.io/api/master/user/:realm/users' \
-d '{
"realmId": "string",
"firstName": "string",
"lastName": "string",
"email": "string",
"enabled": true,
"secret": "string",
"attributes": {},
"serviceAccount": true,
"username": "string"
Request Collapse all
Base URL
Auth
Parameters
— pathrequired
— header
— header
— header
  "email": "string",
  "enabled": true,
  "secret": "string",
  "attributes": {},
