Version: 1.4.0
Delete user asset links
POST
https://demo.openremote.io/api/master/asset/user/link/delete
Body array
  • Array [
  • id object
    userIdstring
    assetIdstring
    assetNamestring
    parentAssetNamestring
    userFullNamestring
curl -L 'https://demo.openremote.io/api/master/asset/user/link/delete' \
-d '[
"id": {
"userId": "string",
"assetId": "string"
"assetName": "string",
"parentAssetName": "string",
"userFullName": "string"
Request Collapse all
Base URL
Auth
Parameters
— header
— header
— header
    "id": {
      "userId": "string",
      "assetId": "string"
