Version: 1.4.0
Retrieve a datapoint period of an asset attribute
GET
https://demo.openremote.io/api/master/asset/datapoint/periods
    assetId string
    attributeName string
    assetIdstring
    attributeNamestring
    oldestTimestampint64
    latestTimestampint64
curl -L 'https://demo.openremote.io/api/master/asset/datapoint/periods' \
Request Collapse all
Base URL
Auth
Parameters
— query
— query
— header
— header
— header
