Retrieve the global rules
GEThttps://demo.openremote.io/api/master/rules
language string[]
Possible values: [JAVASCRIPT
, GROOVY
, JSON
, FLOW
fullyPopulate boolean
- Example (auto)
idint64
lastModifieddate-time
namestringrequired
Possible values: >= 3 characters
and <= 255 characters
rulesstring
langstringrequired
, GROOVY
, JSON
, FLOW
meta object
Possible values: [READY
, DEPLOYED
, COMPILATION_ERROR
, VALIDITY_PERIOD_ERROR
, EXECUTION_ERROR
, LOOP_ERROR
, DISABLED
, PAUSED
, EXPIRED
, REMOVED
, EMPTY
errorstring
"id": 0,
"enabled": true,
"rules": "string",
"lang": "JAVASCRIPT",
"meta": {},
"status": "READY",
"error": "string"
curl -L 'https://demo.openremote.io/api/master/rules' \
