Version: 1.4.0
Retrieve a partially loaded asset (no attributes or path)
GET
https://demo.openremote.io/api/master/asset/partial/:assetId
    assetId stringrequired
    type string
    Possible values: []
    Possible values: >= 0
    accessPublicReadboolean
    parentIdstring
    pathstring[]
    attributes object
    delegate object
    property name* AttributeObject
    type object
    constraints object[]
  • Array [
  • messagestring
    type stringrequired
    Possible values: []
  • format object
    useGroupingboolean
    minimumIntegerDigitsint32
    minimumFractionDigitsint32
    maximumFractionDigitsint32
    minimumSignificantDigitsint32
    maximumSignificantDigitsint32
    asBooleanboolean
    asDateboolean
    asSliderboolean
    resolutionnumber
    dateStylestring
    timeStylestring
    dayPeriodstring
    hour12boolean
    iso8601boolean
    weekdaystring
    erastring
    yearstring
    monthstring
    weekstring
    daystring
    hourstring
    minutestring
    secondstring
    fractionalSecondDigitsint32
    timeZoneNamestring
    momentJsFormatstring
    asNumberboolean
    asOnOffboolean
    asPressedReleasedboolean
    asOpenClosedboolean
    asMomentaryboolean
    multilineboolean
    unitsstring[]
    arrayDimensionsint32
    metaUseOnlyboolean
    jsonTypestring
    Possible values: non-empty, Value must match regular expression ^\w+$
    meta object
    delegate object
    property name* MetaItemObject
    type object
  • Array [
  • messagestring
    type stringrequired
    Possible values: []
  • format object
    useGroupingboolean
    asBooleanboolean
    asDateboolean
    asSliderboolean
    resolutionnumber
    dateStylestring
    timeStylestring
    dayPeriodstring
    hour12boolean
    iso8601boolean
    weekdaystring
    erastring
    yearstring
    monthstring
    weekstring
    daystring
    hourstring
    minutestring
    secondstring
    timeZoneNamestring
    asNumberboolean
    asOnOffboolean
    asOpenClosedboolean
    asMomentaryboolean
    multilineboolean
    unitsstring[]
    metaUseOnlyboolean
    jsonTypestring
    type object
  • Array [
  • messagestring
    type stringrequired
    Possible values: []
  • format object
    useGroupingboolean
    asBooleanboolean
    asDateboolean
    asSliderboolean
    resolutionnumber
    dateStylestring
    timeStylestring
    dayPeriodstring
    hour12boolean
    iso8601boolean
    weekdaystring
    erastring
    yearstring
    monthstring
    weekstring
    daystring
    hourstring
    minutestring
    secondstring
    timeZoneNamestring
    asNumberboolean
    asOnOffboolean
    asOpenClosedboolean
    asMomentaryboolean
    multilineboolean
    unitsstring[]
    metaUseOnlyboolean
    jsonTypestring
    timestampint64
    type object
  • Array [
  • messagestring
    type stringrequired
    Possible values: []
  • format object
    useGroupingboolean
    asBooleanboolean
    asDateboolean
    asSliderboolean
    resolutionnumber
    dateStylestring
    timeStylestring
    dayPeriodstring
    hour12boolean
    iso8601boolean
    weekdaystring
    erastring
    yearstring
    monthstring
    weekstring
    daystring
    hourstring
    minutestring
    secondstring
    timeZoneNamestring
    asNumberboolean
    asOnOffboolean
    asOpenClosedboolean
    asMomentaryboolean
    multilineboolean
    unitsstring[]
    metaUseOnlyboolean
    jsonTypestring
    meta object
    delegate object
    type object
  • Array [
  • messagestring
    type stringrequired
    Possible values: []
  • format object
    useGroupingboolean
    asBooleanboolean
    asDateboolean
    asSliderboolean
    resolutionnumber
    dateStylestring
    timeStylestring
    dayPeriodstring
    hour12boolean
    iso8601boolean
    weekdaystring
    erastring
    yearstring
    monthstring
    weekstring
    daystring
    hourstring
    minutestring
    secondstring
    timeZoneNamestring
    asNumberboolean
    asOnOffboolean
    asOpenClosedboolean
    asMomentaryboolean
    multilineboolean
    unitsstring[]
    metaUseOnlyboolean
    jsonTypestring
    type object
  • Array [
  • messagestring
    type stringrequired
    Possible values: []
  • format object
    useGroupingboolean
    asBooleanboolean
    asDateboolean
    asSliderboolean
    resolutionnumber
    dateStylestring
    timeStylestring
    dayPeriodstring
    hour12boolean
    iso8601boolean
    weekdaystring
    erastring
    yearstring
    monthstring
    weekstring
    daystring
    hourstring
    minutestring
    secondstring
    timeZoneNamestring
    asNumberboolean
    asOnOffboolean
    asOpenClosedboolean
    asMomentaryboolean
    multilineboolean
    unitsstring[]
    metaUseOnlyboolean
    jsonTypestring
    timestampint64
curl -L 'https://demo.openremote.io/api/master/asset/partial/:assetId' \
Request Collapse all
Base URL
Auth
Parameters
— pathrequired
— header
— header
— header
