Version: 1.4.0
Retrieve the rules of a realm
GET
https://demo.openremote.io/api/master/rules/realm/for/:realm
    language string[]
    fullyPopulate boolean
  • Array [
  • idint64
    lastModifieddate-time
    namestringrequired
    rulesstring
    langstringrequired
    meta object
    property name*object
    errorstring
    accessPublicReadboolean
curl -L 'https://demo.openremote.io/api/master/rules/realm/for/:realm' \
Request Collapse all
Base URL
Auth
Parameters
— pathrequired
— query
— query
— header
— header
— header
