Retrieve the vector tile data for Mapbox GL
GEThttps://demo.openremote.io/api/master/map/tile/:zoom/:column/:row
zoom int32required
column int32required
row int32required
- application/vnd.mapbox-vector-tile
- Example (auto)
stringbyte
"string"
curl -L 'https://demo.openremote.io/api/master/map/tile/:zoom/:column/:row' \
