Retrieve the available value descriptors
GEThttps://demo.openremote.io/api/master/model/valueDescriptors
parentId string
- Example (auto)
property name* ValueDescriptorObject
curl -L 'https://demo.openremote.io/api/master/model/valueDescriptors' \
