Update realm roles for a user in a realm
PUThttps://demo.openremote.io/api/master/user/:realm/userRealmRoles/:userId
userId stringrequired
Body array
string
curl -L -X PUT 'https://demo.openremote.io/api/master/user/:realm/userRealmRoles/:userId' \
-d '[
"string"
