Version: 1.4.0
Write to a single attribute
PUT
https://demo.openremote.io/api/master/asset/:assetId/attribute/:attributeName
    assetId stringrequired
    attributeName stringrequired
    objectobject
The result of the write operation
    ref object
    The asset identifier
    Example: 7Bt8M3cXEP6BHPh8r47DYf
    The attribute name
    Possible values: non-empty, Value must match regular expression ^\w+$
    Example: location
    failurestring
    Possible values: [ASSET_NOT_FOUND, ATTRIBUTE_NOT_FOUND, INSUFFICIENT_ACCESS, INVALID_VALUE, INTERCEPTOR_FAILURE, STATE_STORAGE_FAILED, CANNOT_PROCESS, QUEUE_FULL, UNKNOWN, ASSET_ID_MISSING, ATTRIBUTE_NAME_MISSING]
curl -L -X PUT 'https://demo.openremote.io/api/master/asset/:assetId/attribute/:attributeName' \
-d '{}'
Request Collapse all
Base URL
Auth
Parameters
— pathrequired
— pathrequired
— header
— header
— header
