Gateway tunnelling setup
This guide describes the steps necessary to setup the gateway tunnelling functionality which allows remote access to edge gateways using SISH
Edge Instance Setup
SSH keys
mkdir -p deployment/sish/pubkeys deployment/sish/client deployment/sish/keysssh-keygen -t ed25519 -b 4096 -f clientmv client.pub deployment/sish/pubkeysmv client deployment/sish/client(this will be needed by the edge instances) - Optionally encrypt this file using gradle taskssh-keygen -t ed25519 -b 4096 -f server_keymv server_key deployment/sish/keys
Docker envrionment variables
- Set Keycloak container environment variables:
KEYCLOAK_ISSUER_BASE_URI: https://${OR_HOSTNAME}/authKC_HOSTNAME:This must be blank or completely removed (i.e. do not set this environment variable)KC_HOSTNAME_STRICT: false
- Set manager environment variables:
OR_WEBSERVER_ALLOWED_ORIGINS: *OR_GATEWAY_TUNNEL_SSH_KEY_FILE: <PATH_TO_PUBLIC_SISH_KEY>(/deployment/sish/client/cert)OR_GATEWAY_TUNNEL_AUTO_CLOSE_MINUTES: <MINUTES>This optional variable can be set to automatically close tunnels after the specified number of minutes. When it is set to 0 (or not set) tunnels remain open until they are manually closed.
Central Instance Setup
- Proxy container must be able to read/write Route53 DNS TXT record (see https://certbot-dns-route53.readthedocs.io/), this requires the instance to have the required permissions to the Route53 account where the DNS zone is hosted, if the hosted zone is in the same account as the EC2 instance then the standard
ec2-accessIAM profile that is attached to all our EC2 instances already contains the required permissions so no action is needed, alternatively if the hosted zone is in a different account to the EC2 instance then it is important that the EC2 instance cloudformation template parameterDNSHostedZoneRoleArnwas correctly set, this will then get set asAWS_ROUTE53_ROLEin/etc/environmentand the proxy container will output this to~/.aws/configduring startup which will allow the plugin to assume that role for Route53 calls. TheAWS_ROUTE53_ROLEcan alternatively be defined via env file or within the docker compose file itself (NOTE: this role must be assumable by theec2-accesspolicy) - Set
DOMAINNAMESto include wildcard certificate e.g.*.example.openremote.app - Add wildcard DNS A/AAAA record(s) e.g.
*.example.openremote.app - Uncomment/add sish service in Docker Compose profile
- Set
SISH_HOSTandSISH_PORTon proxy container - Set
OR_GATEWAY_TUNNEL*environment variables on manager container - Set TCP port range in sish service (to allow raw TCP tunnelling)
- Allow inbound access to port
2222and to the TCP port range exposed on the instance - Generate or select existing SSH private key and add this to the deployment image and set SISH variable:
--private-keys-directory
