Retrieve all realms
GEThttps://demo.openremote.io/api/master/realm
Retrieve all realms
- Example (auto)
displayNamestring
notBeforedouble
passwordPolicystring[]
resetPasswordAllowedboolean
duplicateEmailsAllowedboolean
rememberMeboolean
registrationAllowedboolean
registrationEmailAsUsernameboolean
verifyEmailboolean
loginWithEmailboolean
loginThemestring
accountThemestring
adminThemestring
emailThemestring
accessTokenLifespanint32
realmRoles object[]
"displayName": "string",
"enabled": true,
"notBefore": 0,
"passwordPolicy": [
"string"
"resetPasswordAllowed": true,
"duplicateEmailsAllowed": true,
"rememberMe": true,
"registrationAllowed": true,
"registrationEmailAsUsername": true,
"verifyEmail": true,
"loginWithEmail": true,
"loginTheme": "string",
"accountTheme": "string",
"adminTheme": "string",
"emailTheme": "string",
"accessTokenLifespan": 0,
"realmRoles": [
"description": "string"
curl -L 'https://demo.openremote.io/api/master/realm' \
