Version: 1.5.0
Retrieve the available asset descriptors
GET
https://demo.openremote.io/api/master/model/assetDescriptors
    parentId string
    parentType string
  • Array [
  • namestring
    iconstring
    colourstring
    dynamicboolean
    descriptorType stringrequired
    Possible values: []
curl -L 'https://demo.openremote.io/api/master/model/assetDescriptors' \
Request Collapse all
Base URL
Auth
Parameters
— query
— query
— header
— header
— header
