Version: 1.5.0
Retrieve client roles for a realm and client
GET
https://demo.openremote.io/api/master/user/:realm/:clientId/roles
    clientId stringrequired
  • Array [
  • idstring
    descriptionstring
    compositeboolean
    assignedboolean
    compositeRoleIdsstring[]
curl -L 'https://demo.openremote.io/api/master/user/:realm/:clientId/roles' \
Request Collapse all
Base URL
Auth
Parameters
— pathrequired
— pathrequired
— header
— header
— header
