Version: 1.5.0
Retrieve the gateway connection of a realm
GET
https://demo.openremote.io/api/master/gateway/connection/:realm
    localRealmstring
    hoststringrequired
    portint32
    Possible values: >= 1 and <= 65536
    clientIdstringrequired
    clientSecretstringrequired
    Possible values: >= 36 characters and <= 36 characters
    securedboolean
    attributeFilters object[]
  • Array [
  • matcher object
    recursiveboolean
    select object
    basicboolean
    accessstring
    Possible values: [PRIVATE, PROTECTED, PUBLIC]
    idsstring[]
    names object[]
  • Array [
  • matchstring
    caseSensitiveboolean
    valuestring
    negateboolean
  • parents object[]
  • Array [
  • idstring
  • paths object[]
  • Array [
  • pathstring[]
  • realm object
    userIdsstring[]
    typesstring[]
    attributes object
    operatorstring
    Possible values: [AND, OR]
    items object[]
  • Array [
  • name object
    matchstring
    valuestring
    negateboolean
    negatedboolean
    pathobject[]
    value object
    predicateType stringrequired
    Possible values: []
    meta object[]
  • Array [
  • name object
    matchstring
    valuestring
    negateboolean
    negatedboolean
    pathobject[]
    value object
    Possible values: []
  • previousValue object
    Possible values: []
    timestampOlderThanstring
  • groupsundefined[]
    orderBy object
    propertystring
    Possible values: [CREATED_ON, FIRST_NAME, LAST_NAME, USERNAME, EMAIL]
    descendingboolean
    limitint32
    durationstring
    deltadouble
    valueChangeboolean
    skipAlwaysboolean
    durationParsedMillisint64
  • assetSyncRules object
    property name* GatewayAssetSyncRule
    excludeAttributesstring[]
    excludeAttributeMeta object
    property name* string[]
  • Array [
  • string
  • addAttributeMeta object
    property name* MetaMap
    delegate object
    property name* MetaItemObject
    type object
    constraints object[]
  • Array [
  • messagestring
    type stringrequired
    Possible values: []
  • format object
    useGroupingboolean
    minimumIntegerDigitsint32
    minimumFractionDigitsint32
    maximumFractionDigitsint32
    minimumSignificantDigitsint32
    maximumSignificantDigitsint32
    asBooleanboolean
    asDateboolean
    asSliderboolean
    resolutionnumber
    dateStylestring
    timeStylestring
    dayPeriodstring
    hour12boolean
    iso8601boolean
    weekdaystring
    erastring
    yearstring
    monthstring
    weekstring
    daystring
    hourstring
    minutestring
    secondstring
    fractionalSecondDigitsint32
    timeZoneNamestring
    momentJsFormatstring
    asNumberboolean
    asOnOffboolean
    asPressedReleasedboolean
    asOpenClosedboolean
    asMomentaryboolean
    multilineboolean
    unitsstring[]
    arrayDimensionsint32
    metaUseOnlyboolean
    jsonTypestring
    Possible values: non-empty, Value must match regular expression ^\w+$
    type object
  • Array [
  • messagestring
    type stringrequired
    Possible values: []
  • format object
    useGroupingboolean
    asBooleanboolean
    asDateboolean
    asSliderboolean
    resolutionnumber
    dateStylestring
    timeStylestring
    dayPeriodstring
    hour12boolean
    iso8601boolean
    weekdaystring
    erastring
    yearstring
    monthstring
    weekstring
    daystring
    hourstring
    minutestring
    secondstring
    timeZoneNamestring
    asNumberboolean
    asOnOffboolean
    asOpenClosedboolean
    asMomentaryboolean
    multilineboolean
    unitsstring[]
    metaUseOnlyboolean
    jsonTypestring
    disabledboolean
curl -L 'https://demo.openremote.io/api/master/gateway/connection/:realm' \
Request Collapse all
Base URL
Auth
Parameters
— pathrequired
— header
— header
— header
