Version: 1.5.0
Retrieve sessions for a user in a realm
GET
https://demo.openremote.io/api/master/user/:realm/userSessions/:userId
    userId stringrequired
  • Array [
  • IDstring
    usernamestring
    startTimeMillisint64
    remoteAddressstring
curl -L 'https://demo.openremote.io/api/master/user/:realm/userSessions/:userId' \
Request Collapse all
Base URL
Auth
Parameters
— pathrequired
— pathrequired
— header
— header
— header
