Version: 1.5.0
Retrieve dashboards using a query
POST
https://demo.openremote.io/api/master/dashboard/query
    select object
    basicboolean
    conditions object
    dashboard object
    accessstring[]
    asset object
    accessstring[]
    Possible values: [RESTRICTED, LINKED, REALM]
    minAmountstring
    Possible values: [AT_LEAST_ONE, ALL, NONE]
    parents object[]
  • Array [
  • idstring
  • idsstring[]
    names object[]
  • Array [
  • matchstring
    caseSensitiveboolean
    valuestring
    negateboolean
  • userIdsstring[]
    realm object
    startint32
    limitint32
  • Array [
  • idstring
    ownerIdstring
    accessstring
    displayNamestring
    template objectrequired
    columnsint32
    Possible values: >= 1
    maxScreenWidthint32
    refreshIntervalstring
    screenPresets object[]required
  • Array [
  • idstring
    displayNamestring
    breakpointint32
    scalingPresetstringrequired
    redirectDashboardIdstring
  • widgets object[]
  • Array [
  • idstring
    displayNamestringrequired
    gridItem objectrequired
    xint32
    yint32
    wint32
    hint32
    minHint32
    minWint32
    minPixelHint32
    minPixelWint32
    noResizeboolean
    noMoveboolean
    lockedboolean
    widgetTypeIdstringrequired
    widgetConfigobject
curl -L 'https://demo.openremote.io/api/master/dashboard/query' \
-d '{
"select": {
"basic": true
"conditions": {
"dashboard": {
"access": [
"PUBLIC"
"asset": {
"access": [
"RESTRICTED"
"minAmount": "AT_LEAST_ONE",
"parents": [
"id": "string"
"ids": [
"string"
"names": [
"match": "EXACT",
"caseSensitive": true,
"value": "string",
"negate": true
"userIds": [
"string"
"realm": {
"name": "string"
"start": 0,
"limit": 0
Request Collapse all
Base URL
Auth
Parameters
— header
— header
— header
  "select": {
    "basic": true
  "conditions": {
    "dashboard": {
      "access": [
        "PUBLIC"
    "asset": {
      "access": [
        "RESTRICTED"
      "parents": [
          "id": "string"
  "ids": [
    "string"
  "names": [
      "match": "EXACT",
      "value": "string",
      "negate": true
  "userIds": [
    "string"
  "realm": {
    "name": "string"
  "start": 0,
  "limit": 0
