Version: 1.5.0
Update attribute values
PUT
https://demo.openremote.io/api/master/asset/attributes
Body array
  • Array [
  • ref object
    The asset identifier
    Example: 7Bt8M3cXEP6BHPh8r47DYf
    The attribute name
    Possible values: non-empty, Value must match regular expression ^\w+$
    Example: location
    valueobject
  • Array [
  • ref object
    The attribute name
    Example: location
    failurestring
    Possible values: [ASSET_NOT_FOUND, ATTRIBUTE_NOT_FOUND, INSUFFICIENT_ACCESS, INVALID_VALUE, INTERCEPTOR_FAILURE, STATE_STORAGE_FAILED, CANNOT_PROCESS, QUEUE_FULL, UNKNOWN, ASSET_ID_MISSING, ATTRIBUTE_NAME_MISSING]
curl -L -X PUT 'https://demo.openremote.io/api/master/asset/attributes' \
-d '[
"ref": {
"id": "7Bt8M3cXEP6BHPh8r47DYf",
"name": "location"
"value": {}
Request Collapse all
Base URL
Auth
Parameters
— header
— header
— header
    "ref": {
      "name": "location"
    "value": {}
