Simulator
Simulate a connection to an external service, useful during development when the real service is un-available etc. It can also be used to automatically replay a fixed set of simulated values over a repeating 24h period.
Agent configuration
There is no configuration required on the agent for this protocol.
Agent link
type | Agent type | Text (Must be SimulatorAgentLink) | Y |
replayData | 24h dataset of values that should be replayed (i.e. written to the linked attribute) in a continuous loop | SimulatorReplayDatapoint[] | N |
Additional info
Attributes linked to this agent that are written to will follow a route through the system as if it came from a remote service.
Simulator Replay Datapoints
Attributes linked to this agent that have a replayData field in their Agent Link will cause the values within to be replayed over a 24h period in a continuous loop. Each SimulatorReplayDatapoint value must have a timestamp (seconds offset from midnight 00:00 in the system time of the machine that hosts the manager) and a value, this value will then be written to the attribute at the specified seconds offset from midnight each day.
