Release Management
Manager
- latest: this tag is updated to always contain the most recent release.
- develop: this tag is used during development for testing changes before an actual release is created. A new "develop" image is built for every commit pushed to the "master" branch. It is not recommended to use this tag in production because it can be unstable.
Custom Projects
- Docker images (published to Docker Hub)
- Java code (packaged as JARs, published to Maven Central)
- TypeScript code (packaged as NPMs, published to npmjs.com)
Updating to new a release
- Read the release notes to get familiar with the changes
- Update the code to use the new version:
- Docker images: Update the
openremote/managerimage tag in thedocker-compose.ymlfile (or environment variable) - Java code: Update the
openremoteVersionin thegradle.propertiesfile - TypeScript code: Update the openremote package dependencies, e.g. using
yarn up -E "@openremote/*@^1.2.0"
- Check that the code in your custom project still builds correctly using:
./gradlew clean installDist
Using snapshot artifacts
openremote/managerimage tag todevelopin thedocker-compose.ymlfile (or environment variable) - Java code: Update the
openremoteVersionto1.3.0-SNAPSHOTin thegradle.propertiesfile (requires the Maven repository https://central.sonatype.com/repository/maven-snapshots to be added to yourproject.gradlefile) - TypeScript code: Update the openremote package dependencies using
yarn up -E "@openremote/*@^1.3.0-snapshot"
Using ORLib
The Android ORLib is maintained in the console-android repository and published as a JAR to Maven Central. The iOS ORLib is maintained in the console-ios repository and published as a CocoaPod to Trunk.
- Remove the Git submodule(s) (
.gitmodules) and each submodule directory (e.g.openremote) - Add dependencies to the new artifacts in your build.gradle and package.json files
- Add the new "model" and "rest" UI component module code
- Update the TypeScript code so classes are loaded from the new modules:
- Add
import rest from "rest";to your imports if necessary - Replace
import ... from '@openremote/model';withimport ... from 'model';if necessary - Replace
manager.rest.apiwithrest.apiwhere applicable
- Add
Local development practices
Local artifacts
Note that the custom project build first resolves artifacts from mavenLocal() which is defined in the project.gradle file.
So once you publish snapshot artifacts to your local Maven repository these will no longer be downloaded from the https://central.sonatype.com/repository/maven-snapshots repository.
To undo this, either comment the mavenLocal() repository or remove your local artifacts in ~/.m2/repository/io/openremote.
Version resolution
The manager build version is resolved based on tags and commits of the Git repository using the Gradle axion-release-plugin.
For this to work correctly it is important your local Git repository has all published tags (i.e. use git pull --tags).
- Per repository:
git config remote.origin.tagOpt --tags - Globally:
git config --global fetch.tagOpt --tags
Creating releases
- Create a tag for the release
- Create a release with release notes
- Trigger a CI/CD build to publish all the release artifacts (i.e. Docker images, JARs, NPMs, CocoaPods)
- openremote/openremote: The "version" in the
package.jsonfiles of all modules in the 'ui' directory - openremote/console-ios: The CocoaPod "version" in the
ORLib/ORLib.podspecfile
