Working on UI and apps
Overview
Working on an app (e.g. Manager UI)
From the main directory, start the required containers, use dev-ui.yml for example: docker-compose -f profile/dev-ui.yml up -dBy default, this makes the manager container serve the apps present in the latest docker image on port 8080 e.g. http://localhost:8080/manager/. While these apps are not necessary for this case, the included manager container webservice is.
cdinto the app directory e.g.ui/app/managerand run the followingnpmscript:npm run serve
Webpack dev server environment variables
The following environment variables can be set when running npm run serve using the syntax npm run serve "--" --env ENV_NAME=ENV_VALUE:
- managerUrl - By default webpack dev server expects the manager to be available at http://localhost:8080but this can be configured for example when running the manager Docker image (e.g.npm run serve "--" --env managerUrl=https://localhost)
- keycloakUrl - By default Keycloak expects to be available at managerUrl/authbut this can be configured for example when running the manager Docker image (e.g.npm run serve "--" --env keycloakUrl=https://keycloak/auth)
Consuming UI components
UI development
- Front end applications
- Front end components and their demos, shared between applications
- Keycloak theme(s) used in authentication screens
- Run a Manager instance in an IDE (refer to Setting up an IDE)
- Deploy the Manager using a Docker container (refer to UI Development profile)
UI Components & Apps (/ui)
- component- Base OpenRemote JS modules and web components (built using Polymer) these are written as ES6 modules
- app- Built-in OpenRemote web applications (applications can be built with whatever frameworks/libraries are desired)
- demo- Demos of each web component (provides a development harness for developers working on the components)
- clean- Cleans up any build artefacts (typically uses the- shxpackage)
- build- Build the component/app ready for publishing/deployment
- test- Run any automated tests
- modelWatch- Starts a- gradletask to watch the- javamodel code and to run the- typescriptgenerator when changes are detected, the generated- modeland- restclienttypescript code is then transpiled to- javascript
- modelBuild- Similar to- modelWatchbut just does a onetime build rather than watching for changes
- serve- Starts- webpack dev servertypically on- http://localhost:9000/[app|demo]/
Running Manager UI against remote instance
- Add https://localhost/*to Valid redirect URIs of openremote client in master realm of remote instance keycloak
- Ensure remote instance manager container has localhostlisted inOR_ADDITIONAL_HOSTNAMES(note this variable is comma separated list of hostnames)
- Run the dev-proxy.ymlcompose profile locally
- Access shell in proxy container: docker exec -it <PROXY_CONTAINER_NAME> ash
- Add the following snippets to the proxy config (Press i for insert mode, when finished press Esc then : then wq): vi /etc/haproxy/haproxy.cfg- Above the use_backend manager_backendline
- Above the
    acl webpack path_beg /manager
- Above the backend manager_backendline:
- Ctrl/Cmd-D to exit the proxy container shell
- Start the webpack dev server in the ui/app/manager:npm run serve "--" --env managerUrl=https://demo.openremote.app
Components
Maps
Apps
Demos
