Bluetooth Mesh
Connect to a Bluetooth Mesh network via a Bluetooth Mesh proxy. Note that only Linux Docker host systems with a bluez protocol stack is supported.
Make sure that the file docker-compose.yml contains the following configuration settings:
volumes:
  btmesh-data:
  manager:
    privileged: true
    volumes:
      - /var/run/dbus:/var/run/dbus
      - btmesh-data:/btmesh
Agent configuration
| Attribute | Description | Value type | Required |
networkKey | Bluetooth Mesh network key | Text, format: <key index>:<key> (e.g. 0:5EBBC0FE3CCEF029C049B00F27DC8A5C) | Y |
applicationKey | Bluetooth Mesh application key | Text, format: <key index>:<key> (e.g. 0:2AD08F7660AA535FA7DE4C918241F04F) | Y |
proxyAddress | Bluetooth Mesh proxy address - if omitted proxy with best RSSI is selected | Text (e.g. B0:CE:18:A3:0B:09) | N |
sourceAddress | Bluetooth Mesh source unicast address | Text, format: 4 hexadecimal digits (e.g. 199A), range: 0001-7FFF | Y |
mtu | Maximum transmission unit size for Bluetooth Mesh proxy communication - if omitted default value is 20 | Positive Integer | N |
sequenceNumber | Bluetooth Mesh sequence number - if omitted default value is 1 | Positive Integer | N |
Agent link
address | Bluetooth Mesh destination unicast address | Text, format: 4 hexadecimal digits (e.g. 0002), range: 0001-7FFF | Y |
appKeyIndex | Bluetooth Mesh application key index | Positive Integer | Y |
modelName | Bluetooth Mesh model name | Text (e.g. GenericOnOffClient) | Y |
Note that currently only the GenericOnOffClient Bluetooth Mesh model is supported.
