CI/CD pipeline
This document describes the continuous integration and continuous deployment (CI/CD) pipeline of the core repository, introducing the concepts and workflows added in our pipeline migration (#2696). The pipeline runs on GitHub Actions and its workflows are in the .github/workflows directory.
Overview of the workflows
The pipeline is structured using a separation of concerns between environments and jobs:
- Environment Workflows: These are context specific workflows that act as the orchestrator for different triggers:
review.ymlfor pull requests and the merge queue.staging.ymlfor pushes tomainand release tags. It builds, tests and publishes the Docker images, Maven artifacts and npm packages.deploy.ymlfor manual deployments.custom-review.yml,custom-staging.ymlandcustom-deploy.yml, which custom projects call from their own workflows.
- Job Workflows: These are reusable workflows (
workflow_call) that contain the actual steps for specific tasks (like running tests, building dists, or publishing artifacts). Environment workflows call these job workflows, which prevents duplication.
The previous pipeline, ci_cd.yml, is kept for custom projects that have not migrated to the new workflows yet.
How reusable workflows work
Job workflows are configured as reusable workflows. This allows them to be shared across multiple environments.
A job that calls a reusable workflow reports a status check for each job in that workflow, named <calling job> / <job>. For example, the unit-tests job in review.yml is named Test and calls unit-tests.yml, whose job is named Unit Tests, so the check is Test / Unit Tests. Branch protection on main requires these checks by name.
Composite actions
Composite actions are defined under .github/actions and act as reusable steps (unlike reusable workflows, which act as reusable jobs). We use them to keep the workflows DRY (Don't Repeat Yourself), so the same steps aren't duplicated across workflows.
How the pipeline works
Detect changes
We use a "detect changes" job early in the workflow to determine which files have been modified. Subsequent jobs use the outputs of this job as their skip condition:
backend_any_modified: Unit and integration tests only run when backend code changed.ui_any_modified: UI component tests only run when UI code changed.any_modified: The build, the manager image and the UI app tests run for any backend or UI change, because the UI app tests run against the whole stack.backend_spotless_any_modifiedandui_spotless_any_modified: The Spotless checks only run when files checked by Spotless changed.
For example:
- A PR that only touches backend Java code skips the UI component tests, but still runs the UI app tests.
- A PR that only touches UI code skips the backend unit and integration tests, so only the build and the UI related jobs run.
- A PR that only changes Markdown files skips the build and all tests, but still runs the Spotless checks.
Handling skipped jobs
If the calling job is skipped, GitHub only reports a check for the calling job (e.g. Test), so required checks like Test / Unit Tests are never reported and the PR waits for them indefinitely. A required check that is reported as skipped does satisfy branch protection, so you need to handle skipping inside the reusable workflow itself rather than skipping the entire workflow_call.
Each job workflow that can be skipped therefore has a skip input that its job checks, and the environment workflow passes the skip condition:
# review.yml
unit-tests:
needs: detect-changes
if: ${{ !failure() && !cancelled() }}
uses: "./.github/workflows/unit-tests.yml"
with:
skip: ${{ needs.detect-changes.outputs.backend_any_modified != 'true' }}
# unit-tests.yml
on:
workflow_call:
inputs:
skip:
type: boolean
description: Skip condition to allow branch protection checks to pass
default: false
jobs:
unit-tests:
if: ${{ !inputs.skip }}
The !failure() && !cancelled() condition on the calling job is explained in Special conditions.
Special conditions
You will often see special conditionals used in the pipeline:
if: ${{ !failure() && !cancelled() }}: Used on most jobs in the environment workflows. By default, a job is skipped when a job it needs was skipped. This condition lets it run anyway, unless a job it needs failed or the workflow run was cancelled.if: always(): Ensures a step or job runs regardless of whether previous steps or jobs failed. This is typically used to ensure test results and coverage reports are uploaded even when tests fail, and for theUI App Tests Statusjob.if: failure(): Runs a step only when a previous step in the job failed, or a job only when a job it needs failed. Use it to clean up environments or post error notifications.
Sharding UI app tests
To speed up the UI app tests, ui-app-tests.yml splits them into shards using a matrix job (shardIndex and shardCount). Each shard runs a part of the tests in parallel using the Playwright --shard option and uploads its own test report. fail-fast: false lets the other shards finish when one fails, so you see all failing tests at once.
A matrix job reports a check for each shard, but when the job is skipped it reports a single check without the matrix values. The checks of the individual shards therefore can't be required by branch protection. Instead, the UI App Tests Status job runs after the shards with if: always() and combines their results: it fails when a shard failed or was cancelled, and succeeds when the shards succeeded or were skipped. Branch protection requires this check instead of the shard checks.
Deployments
Deployments are done by the reusable deployment.yml workflow. It builds the deployment, determines which environments to deploy to and runs the .ci_cd/deploy.sh script for each of them. By default, it checks the type of event that triggered the workflow (for example a push to a specific branch) and deploys to the environments configured for that event in the deploy configuration in .ci_cd/ci_cd.json. When you dispatch a deployment manually on a branch, you choose the environment with the ENVIRONMENT input instead. When you dispatch it on a tag, the workflow_dispatch deploy entry in .ci_cd/ci_cd.json is used instead of the ENVIRONMENT and MANAGER_TAG inputs.
In the core repository, staging.yml does not deploy. Deployments, for example to test servers, are triggered manually with the deploy.yml dispatch workflow. To reduce the deployment time significantly, it only runs the jobs a deployment requires (install-dist and deployment) and skips the tests.
Custom projects deploy with custom-staging.yml and custom-deploy.yml, see Custom projects.
Custom projects
Custom projects reuse the pipeline by calling the following workflows of the core repository from their own workflows:
| Workflow | Trigger in the custom project | Stages |
custom-review.yml | Pull requests | Lint, build, and test. |
custom-staging.yml | Pushes | The same as custom-review.yml, followed by a deployment when no job failed and .ci_cd/ci_cd.json configures one for the pushed branch. |
custom-deploy.yml | Manual (workflow_dispatch) | A deployment using deployment.yml. |
Reference the core workflows by release version rather than a branch like main, so changes to the core pipeline don't unexpectedly break custom projects. When no release includes the workflow changes you need, reference a commit SHA instead, with a comment naming the closest release (git describe --tags --abbrev=0 <commit-sha>). For example, releases up to 1.32.2 don't include these workflows, so you reference the merge commit of #3441 or later:
uses: openremote/core/.github/workflows/custom-review.yml@b5e84f1b83b64c7808b59823dfd0a9cd3cee1c8f # 1.32.2
The exception is custom-project-test, which references main on purpose to catch issues with changes to the core pipeline early.
The core workflows use ${{ github.workflow }}-${{ github.ref }} as their concurrency group, and in a called workflow github.workflow is the name of the calling workflow. Don't use the same concurrency group in the calling workflow, because GitHub cancels the run as a deadlock.
Differences from the core workflows
The custom project workflows differ from the core workflows in the following ways:
- Build: They build with
custom-install-dist.yml, which only runs./gradlew installDist. The archive steps ininstall-dist.ymlassume the layout of the core repository (e.g.ui/util), and no custom project job downloads those artifacts. The build includes the deployment, and changes to thedeploymentdirectory count as code changes, so a broken deployment build already fails in review. - Code coverage: Not run yet, because
code-coverage.ymlrequires JaCoCo outputs and thecombinedCoverageReportGradle task. - Manager version: Deployments use the manager Docker image matching the
openremoteversion ingradle/libs.versions.toml. Snapshot versions are not supported. - Deploy script:
deployment.ymlruns the.ci_cd/deploy.shscript of the core repository at the sameopenremoteversion. Up to 1.32.0, this script reads theIS_MAIN_REPOenvironment variable and theopenremote/.ci_cddirectory, sodeployment.ymlprovides both.
Manual deployments
Custom projects call custom-deploy.yml instead of deploy.yml or deployment.yml, so they don't depend on the inputs of deployment.yml. It must be called from a workflow_dispatch workflow:
on:
workflow_dispatch:
inputs:
ENVIRONMENT:
description: "Environment to use (if any)"
CLEAN_INSTALL:
description: "Delete data before starting"
type: boolean
COMMIT:
description: "Repo branch or commit SHA to checkout"
OR_HOSTNAME:
description: "Host to deploy to (e.g. demo.openremote.app)"
OR_ADMIN_PASSWORD:
description: "Admin password override"
jobs:
deploy:
uses: openremote/core/.github/workflows/custom-deploy.yml@<version>
with:
INPUTS: ${{ toJSON(inputs) }}
secrets: inherit
The calling workflow must be on the default branch before you can trigger it from the GitHub UI.
Migrating from ci_cd.yml
The new workflows report different status checks than ci_cd.yml. When you migrate a custom project, remove the CI/CD / CI/CD check from the required checks in its branch protection and add the checks of custom-review.yml instead. Their names start with the name of the job that calls custom-review.yml (see How reusable workflows work):
<calling job> / Detect whether code changed<calling job> / Lint / Backend Check Spotless<calling job> / Lint / UI Check Spotless<calling job> / Build / Install Dist<calling job> / Test / Unit Tests<calling job> / Test / Integration Tests
Making changes to the pipeline
Testing changes
When modifying the pipeline, you should generally branch off main and test your changes by opening a pull request. Since the workflows run automatically for PRs, you can iterate on pipeline changes within the PR itself.
Changes to .yml files do not count as code changes when detecting changes, so a PR that only changes workflows skips the build and test jobs. To run the jobs you changed, temporarily include a change to a source file in your PR.
To test changes without polluting the main repository, you can:
Push to your own fork and test against custom branches.
Test dispatchable workflows manually. Note that if a workflow file has not been merged to
mainyet, you cannot trigger it from the GitHub Actions UI. Instead, you must use the GitHub CLI to trigger it on your feature branch:gh workflow run <workflow-name.yml> --ref <your-feature-branch>noteIf you are adding a completely new dispatchable workflow file, it won't be recognized by GitHub at all until it is registered. A common workaround is to temporarily add an
on: [push]event to the workflow, push your branch so it runs once, and then remove thepushevent. After this, it will be available to trigger via the CLI.
Writing and updating composite actions
To write or update a composite action:
- Create an
action.ymlfile in a dedicated folder under.github/actions. - Define
runs: using: "composite". - Reference the action in a workflow using
uses: openremote/core/.github/actions/your-action-name@<commit-sha>.
Don't reference actions with a local path like ./.github/actions/your-action-name in workflows that custom projects also use. A local path is resolved in the checked-out repository, which is the custom project in that case.
After changing a composite action, update the commit SHA in the workflows that use it to the SHA of the commit that changed the action on your PR branch. Because PRs are squash merged, this SHA differs from the SHA of the commit that ends up in the history of the main branch, so it points to a dangling commit. This could become an issue if the repository is ever garbage collected, also for the custom projects that call these workflows. We accept this risk, because it is less cumbersome than waiting for the PR to be merged and then creating a follow-up PR to update the commit SHAs, or changing the merge rules to allow merging individual commits.
If you reference a commit on main instead, Dependabot considers the reference to follow the main branch. Every time a new commit is merged, it opens a PR to update the SHA to the latest commit on main, even though the action didn't change (see #3067, #3081 and #3087). #3093 stopped these PRs by pointing the references to a commit that is not part of the main history.
Dependabot also updates the actions used inside our composite actions. When it does, add a commit to the Dependabot PR as described above (see #3301).
Guidelines
Gradle vs. workflows
A good rule of thumb is:
- Use Gradle to manage the internal build lifecycle, task graphs, dependencies, and code compilation.
- Use Workflows for orchestration, conditional job execution (e.g., detect changes), environment provisioning, and deployment.
If a task can be optimized or defined within Gradle (such as skipping a task with -x), prefer that over complex bash scripts in the workflow. For example, install-dist.yml runs ./gradlew installDist -x :deployment:installDist, because the core repository builds the deployment in deployment.yml. However, if skipping a process depends on the GitHub PR context (like changes to specific directories), manage it at the workflow level.
Minimal dependency installation
Installing fewer dependencies is an optimization in itself, because every dependency a job installs adds download and setup time. Jobs should therefore only install what they need. For example, install-browsers.yml only installs the chromium-headless-shell Playwright browser (at the Playwright version from ui/test/package.json) instead of all Playwright browsers.
Install shared dependencies once, early in the pipeline. install-browsers.yml downloads the Playwright browser once and runs in parallel with the build, before the UI component tests and the UI app test shards start. These jobs then get the browser from an artifact instead of each downloading it themselves. The download time of the Playwright browser differed a lot per shard, so downloading only once also made the pipeline more stable. Likewise, jobs download the build outputs of install-dist instead of building them again.
Checking out with Git LFS
Only use lfs: true in the actions/checkout step if the job actually requires files stored in Git LFS (like the *.mbtiles map tiles). Checking out LFS files adds significant time and bandwidth overhead, so it is omitted where possible.
Artifacts
Artifacts are used to share files between isolated jobs.
The most important rule for artifacts is to split them where possible and create artifacts containing only the bare necessities for each specific job.
- What to include: Only the files downstream jobs need, such as build outputs, test reports and coverage files. Select specific build outputs, like
install-dist.ymldoes for the UI component build, rather than uploading fullbuildfolders. Only upload a full folder when downstream jobs need all of it: theor-manager-buildartifact containsmanager/build, because the manager image build, the UI app tests and deployments use the manager distribution in it. Never uploadnode_modules. - When to use them: Only pass artifacts when a downstream job strictly requires the output of an upstream job. Artifact upload/download takes time and consumes storage. Anyone with read access to the repository can download its artifacts, so never include secrets or other sensitive data.
- Optimization through splitting: Uploading separate, minimal artifacts (e.g.,
install-dist.ymlsaves the manager build, UI component build and UI app build as separate artifacts rather than one massive archive) ensures downstream jobs only download exactly what they need, significantly speeding up the pipeline.
File modified metadata tricks
To avoid rebuilding components when passing artifacts between jobs, we update file modified metadata after downloading artifacts. For example, jobs that use the downloaded UI component build run find . -name "*.tsbuildinfo" -exec touch {} +. This makes the TypeScript compiler recognize that the downloaded build output is up-to-date, preventing unnecessary compilations. Run npx tsc -b --verbose to see why TypeScript considers a build out of date.
Caching
We implement several caching strategies to speed up builds:
- Gradle:
actions/setup-javawithcache: "gradle"restores the Gradle dependencies and wrapper at the beginning of jobs, to skip downloading them again. - Docker Images: Docker layer caching is used to avoid rebuilding unmodified layers. We utilize the GitHub Actions cache backend for Docker buildx (
type=gha).
Timeouts
Always add timeout-minutes: 20 (or an appropriate limit) to any step or job that could potentially hang (such as tests or network-dependent operations). This prevents stalled runners from consuming pipeline minutes indefinitely.
Secrets
- Explicit Secret Passing: When calling reusable workflows, explicitly pass the required secrets:
Alternatively, usesecrets:DOCKERHUB_USER: ${{ secrets._TEMP_DOCKERHUB_USER }}DOCKERHUB_PASSWORD: ${{ secrets._TEMP_DOCKERHUB_PASSWORD }}
secrets: inheritif you trust the downstream workflow and it requires all secrets, likedeployment.yml. - Avoid
toJSON(secrets): Never pass secrets to another workflow by serializing the entire secrets object withtoJSON(secrets). This is a security risk as it exposes all environment secrets to potentially untrusted outputs or logs.
