Data migration
DB Functions
Examples
Add/Update meta items to specific attribute of asset(s)
FROM asset a WHERE...;
Remove meta items from specific attribute of asset(s)
Remove attributes from specific asset(s)
Add attribute to specific asset(s) (with meta items)
Add attribute to specific asset(s) (without meta items)
