Docker Compose profiles
Docker services
The following services are used by the main OpenRemote code base:
- proxy - Reverse SSL proxy (HAProxy) for the web services with auto SSL certificate generation (Let's Encrypt)
- manager - Runs the OpenRemote Manager (by default depends on PostgreSQL and Keycloak)
- postgresql - PostgreSQL DB
- keycloak - Keycloak identity provider service
- map - tileserver-gl service that is used for serving map tiles (not required)
Docker Compose profiles (Docker Compose .yml files) are used to configure and start required services; the standard profiles are located in the profile folder of the main OpenRemote repository although the demo profile is in the root of the repo.
The standard profiles are:
Deploy (deploy.yml)
This is the main profile which all other profiles extend; it can't be used directly.
Demo (../docker-compose.yml)
This is a demo profile which starts all services and provides a quick start for getting a running local deployment.
Prerequisites
Docker images must have been pulled from Docker Hub:
docker compose pull
Or the Docker images must have been built locally (requires the full stack be built):
./gradlew clean installDist
docker compose build
To start the containers:
docker compose up -d
UI Development (dev-ui.yml)
This is for doing development work on the UI without having to run the manager in an IDE.
Prerequisites
docker compose -f profile/dev-ui.yml pull
Or the docker images must have been built locally (requires the full stack be built):
docker compose -f profile/dev-ui.yml build
docker compose -f profile/dev-ui.yml up -d
Exposed Services
- Manager: http://localhost:8080
- Keycloak: http://localhost:8081
- PostgreSQL DB: jdbc:postgresql://localhost:5432/openremote
Full Stack Development / Running Tests (dev-testing.yml)
This is for running tests or doing development work on the Manager (in an IDE), see the Setting up an IDE guide for running the Manager in an IDE.
Exposed Services
- Keycloak: http://localhost:8081/auth
Full Stack Development with HTTPS Proxy (dev-proxy.yml)
This is the same as the Full Stack Development profile but also adds the proxy service to allow development/testing of the Manager running behind the reverse proxy with HTTPS (so development environment matches final deployment configuration).
To use this proxy correctly you will need to set the correct environment variables for the manager running behind SSL proxy as described in Setting up an IDE.
Exposed Services
- Manager: https://localhost
Map (dev-map.yml)
This is used for starting the map service and is required when working on raster map components/apps.
Exposed Services
- Tileserver-gl: http://localhost:8082
